Old 09-03-2006, 11:36 PM
deucejr15 deucejr15 is offline
series vs. parallel
I am thinking about buying 2 12" audiobahn AW1200V's.
I want to put them in a sealed enclosure, but I am not sure how to wire them since I have never done this before.
Should I wire them in series or parallel?
Old 09-03-2006, 11:41 PM
alphalanos alphalanos is offline
Re: series vs. parallel
Dont buy them. Save your money and buy something else. Anything else, really.
96 EJ6. Future home of boosted B18C1.
Old 09-03-2006, 11:56 PM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
dont buy audiobahn...seriously dont....but it all depends on the configuration of the woofers... dual 2 ohm or dual 4 ohm. wiring dual 4 ohm in parallel with one woofer will make an amp "see" a 2 ohm load. if you have two woofers and you wire them both in parallel the amp will see 1 ohm.
if your woofer is dual 2 ohm voice coil, then wiring one sub in parallel wil create a 1 ohm load. nad having two will make a .5 ohm load....most amps are not stable at this configuration....so it all depends on what you want
1 DVC 4 ohm woofer parallel= 2 ohms
1 DVC 2ohm woofer parallel= 1 ohm
2- DVC 4ohm woofers- parallel=1 ohm
2- DVC 2 ohm woffers-parallel=.5 ohms
1 DVC 4ohm woofer- series= 8 ohm
1 DVC 2 ohm woofer- seires= 4 ohms
2-DVC 4 ohm woofers series= 4 ohms
2 DVC 2 ohm woofers seires= 2 ohm
got it?
car audio guru...
Old 09-04-2006, 12:26 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
That's series/parallel
2 dvc 4ohm woofers in series/series would be 16 ohm, and 2 dvc 2ohm woofers would be 8 ohm
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-04-2006, 02:33 AM
my bad....i never wire my ohm loads that high anyway...
car audio guru...
Old 09-04-2006, 11:01 AM
so is there a way i can wire 2 dvc 4-ohm subs in 4 ohms to a 2-channel amp?
Old 09-04-2006, 11:08 AM
Dude, give up on Audiobahn. Seriously. Its garbage.
Old 09-04-2006, 11:26 AM
what do you suggest for an amp and 2 12"? I would like to spend no more than $400.
Old 09-04-2006, 12:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
I'm not an SPL guy ... but seems like I have seen lots of subs on here for like $100 ea or so.
Old 09-04-2006, 01:05 PM
sr20de4evr's Avatar
Yeah most people don't, I just figured I would throw it out there
There are a couple of subs with quad 1ohm coils, that's about the only situation where someone might wire in series/series that I can think of.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-04-2006, 01:07 PM
sr20de4evr's Avatar
Series/parallel (which means both series and parallel...the 2 coils on each sub are wired in series, and then the 2 subs are wired in parallel) would bring 2 dual 4ohm subs to a single 4ohm load which would work well on a bridged 2ch amp
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-04-2006, 01:48 PM
thanks alot. now i think i understand where you are goin with this.
Old 09-04-2006, 03:50 PM
PlayStation3 PlayStation3 is offline
i found a site that have alipne type r's for only 110. and the amp is 200 on the site too.
and that sit eis techronics.com
Old 09-04-2006, 05:32 PM
yea two type r's $100 a piece. hifonics tx1005d 1000 watts rms at 1 ohm amp for about $150. youre set!
car audio guru...
