Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-03-2006, 06:03 PM
scoopy03 scoopy03 is offline
1984 5.0 stalled up
my neighbor's 5.0 is stalled up. the engine wont spin. we r trying to find out how can u get it to atleast get the oil through the engine. he heard that u take out the dist. and u put a drill in it to make the rod to turn.
Old 09-03-2006, 06:49 PM
eggfarmer eggfarmer is offline
Re: 1984 5.0 stalled up
Lets make sure it's not locked up first (before you brake the lobe inside).Pull all your plugs out and turn it over. While doing this you can also make sure you are getting a good blue spark. If it does'nt crank put a socket on the crank bolt/nut and try it that way(with the plugs out also). Gotta be safe!!
Old 09-03-2006, 07:50 PM
he started to try that but didnt want to break the crank bolt. and the plugs are already out of it.... so i guess u can say it is locked up.
Old 09-03-2006, 09:00 PM
Now that does'nt sound good, next I would pull the vave covers and look for bent valve(s).Just by some weird quirk--the starter might also be jammed in the flywheel.
Old 09-04-2006, 03:44 PM
there would be no bent valves..... its a rebuilt engine pretty much built from the ground up..... we got the oil through the engine and head and all though today and there is good oil pressure..... pushrod is new.....
Old 09-04-2006, 04:08 PM
so--- if you got oil pressure,then you got the motor to spin?
Old 09-06-2006, 12:19 AM
no we had to use an extra dist we had found lying around and we took off the gear and the top cover and manually twisted it for awhile until we got the drill charged up and then it was really quick.... but when we twisted the top counterclockwise u could feel the oil pump resisting.... we tried again to put a socket on the crank bolt to turn over the engine and its there really extremely tight now.... we're going to have to take it apart i guess to see maybe it the crank it too torqued or something like that... oh about the starter it ISNT stuck in between the flywheel.....
fyi : this info on how to do this was found in haynes repair manual for mustangs
Old 09-06-2006, 10:33 PM
sorry, did'nt mean to get ya all "cranky". i have the same book and then some others that I allways cross referance.But hey, I'm having my troubles also and the Haynes bool does'nt seem to cover it.
