Old 09-03-2006, 03:33 PM
cruick44 cruick44 is offline
ABS Light Comes On
My 99 Taurus SE gets an ABS light after about 10 minutes of driving when cold. On hot days its on all the time. Any ideas?
Old 09-03-2006, 04:00 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ABS Light Comes On
You need to find a good repair shop with a ABS capable scanner and get the abs codes.
Post back code no and someone can help you.
Also you need to take a look at the abs sensor rings and wiring.
Ford has problems with cracked or slipped sensor rings.
Also check for codes when the abs light is on before key off.
MT
MT
Old 09-03-2006, 04:19 PM
Thanks for the advice. When the light is on, is the ABS not functioning?
Old 09-03-2006, 04:41 PM
MT-2500's Avatar
AF - Advisor
Depends on the problem.
May or not function but if the light is on there is a problem,
So do not count on them to be working.
Or get in a situation where your life may depend on them.
MT
MT
