Old 09-03-2006, 02:23 PM
Bill-SILV Bill-SILV is offline
Spray on bedliner
The other post got me curious...
What is you guys opinion on the spray in bedliners? I checked into it and they want $450 to do it here and I can buy the stuff from the hardware store for $99. I heard it is not as good. Any Suggestions.
Old 09-03-2006, 06:14 PM
8Pack's Avatar
8Pack 8Pack is offline
Re: Spray on bedliner
It's not any good. Go ahead and spend the extra 3 bills and get it done right. You'll be glad you did.
2003 Chevrolet Silverado 2500HD 6.0 CC SB 4X4
Old 09-08-2006, 11:15 AM
jveik jveik is offline
it is just as good as the stuff a shop does, but there is no way in hell that you can do the job in as good of a quality as the shop can. trust me, i tried putting some on the floorboards in my 73 chevy c-10 im restoring and it is a constant flurry of cussing when little stringers fling off the roller and land on that fresh new paint i spent months putting on the truck lol it was horrible, though i quickly utilized a brush and things went a little more smoothly. it is a very surprisingly tedious process and it will never look good unless you pay some pros to do it.
Old 09-08-2006, 07:12 PM
Dont they use a paint sprayer, but just one that uses a bigger nozzle.
Old 09-08-2006, 08:31 PM
TwentyPints TwentyPints is offline
you get what you pay for.
K&N High-Flow Air Filter
Flowmaster 40 Series Muffler (Dual Out)
Vibrant Performance Exhaust Tips
BFGoodrich Mud-Terrain T/A LT265/75R16
Clarion Pro Audio System
Old 09-09-2006, 01:58 PM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
Spray on bedliners are only as good as the installer. The pros can put on a much thicker coat than you will get doing it yourself, but get references. I have seen these things peel because they weren't prepped properly. I have seen some pretty shitty jobs come out of one of the local shops. One of the other shops do a really fine job............like I said get references.
"What in the wide, wide world of sports is a go'in on here?" - Taggert
Old 03-09-2007, 08:57 PM
jschro jschro is offline
stuff in the hardware store for 100 dollars is for a gallon of thick paint. the good sprayed on liner such as ultimate sprayed on polyurethane or the xtreme hi pressure polyurea spray is applied up to 1/4 inch thick and on an 8 foot bed over 7 gallons are applied. take your hardware variety of one gallon and multiply that times 7 and you are at 700 dollars just for the materia and then labor. But you cannot put it on that thick because of the type of material it is for sure. It is a bargain for 450 dollars to have your truck sprayed.. Check out the Ultimate linings material, Best stuff anywhere. It has to be sprayed by a dealer because of the special mix equipment, and it dries in seconds, and you can beat the heck out of it, lifetime warranty, and adds lots of resale value to your truck. Ultimate linings and xtreme linings are made by the same company ultimate linings out of Houston Tx.
Old 03-09-2007, 09:02 PM
spray on from a good dealer is the only way to go. check out ultimate linings out of Houston tx. website www.ultimatelinings.com Best product on the market. we are a dealer for ultimate and xtreme spray on
liners and are trying to educate the truck owners on what is best for their trucks. our website is www.ultimatelv.com in northeast pa.
Old 03-10-2007, 08:56 AM
thadrawr's Avatar
thadrawr thadrawr is offline
Send a message via AIM to thadrawr
line-x it once and you will never need it done again
1999 GMC Sierra 1500
Old 03-10-2007, 10:56 AM
yes, linex is pretty good, but xtreme by ultimate is up one on linex because linex is 35% polyurea and 65% polyurethane, in which Xtreme linings is 70% polyurea and 30% polyurethane. tougher and less fade resistant because polyurea is much more uv stable.
Old 04-12-2007, 08:08 PM
Line-X Expert Line-X Expert is offline
The more polyurea the harder it is - also the more like steel it feels like - also the more stuff slides around - also less vibration dampening. Line-X is definitly strong enough and has a nation wide warranty. Check out www.linexpics.com for some crazy custom Line-X work.
Old 04-13-2007, 11:17 AM
check out xtremeliners.com also
Old 04-17-2007, 11:11 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
I just did my own spray in bedliner. It is awesome. I used a paint code and used about a pint or more to tint it. I got a kit from Eastwoodco.com It is the SEM Pro-Tex gallon size tintable kit. COmes with all the goodies you need. This is the newer formula they have that retains gloss, and is more durable.
SWEEEEEET
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
