Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-03-2006, 01:19 PM
Anderia Anderia is offline
88 Cutlass Supreme
I have an 88 Cutlass Supreme. The service engine light has been going off and on, I dont know if that is something to do with the problem. All of a sudden, car would start up and then die. After a few times of dying, it would idle but then seem to have power surges, it would try to die, but then idle itself back up. When you go to drive it, sometimes it would run fine after a few minutes. But each time it is shut off and you go back to start it, it does the same thing over again. Someone please help!!
Old 09-03-2006, 02:03 PM
maxwedge maxwedge is offline
A990 racer
Re: 88 Cutlass Supreme
Welcome to AF, get it scanned for the source of the check engine lite problem, there are many possibilities here and the limited info provided is insufficient to really provide any comprehensive help, post back the codes. Are you up to jumping the a and b terminals in the obd connector for flash codes?
Old 09-03-2006, 10:08 PM
Sure, but I have no clue as to what you are referring to. I had a car before that you could turn the ignition over to run I think 3 times and then the engine light would flash and you had to count them for the code. Is this what you are talking about?
Old 09-04-2006, 02:06 PM
A990 racer
Exclamation Re: 88 Cutlass Supreme
There is a diagnostic port under the dash, square black box, small, you have to jump a and b pins, it sounds like you really should get professional help with this.
Old 09-04-2006, 04:08 PM
Codes are 33, 34, and 45.
Old 09-04-2006, 10:03 PM
CutlassOlds88 CutlassOlds88 is offline
Try replacing the MAF sensor
Old 09-05-2006, 03:40 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with CutlassOlds88, the code 33 and 34 both refer to the MAF sensor on your vehicle (or MAP sensor for vehicles not equipped with a MAF). When both these codes are shown at the same time, it indicates a shorted MAF/MAP sensor. The code 45 is rich exhaust, caused by the bad MAP/MAF sensor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-05-2006, 06:32 PM
Thanks alot. I had it taken off today and it looked like the wires that ran to the connector had been nicked or cut somehow, then there was electrical tape that was over them, which had worn off and wasnt even covering the exposed wires anymore.
Old 09-06-2006, 12:26 AM
Laramore Laramore is offline
where exactly is the sensor located?
Old 09-06-2006, 01:13 AM
it's located right next to the air cleaner
Old 09-16-2006, 04:46 PM
Well I ended up changing the MAP sensor. Still had the same problem. So my husband was messing around and found out that FWD does have both a Map sensor and an air flow sensor. Replaced it and the car hasnt stalled since, and the engine light went off.
Thanks to all that helped.
