Old 09-03-2006, 06:08 AM
hany's Avatar
hany hany is offline
engine code places?
where to find the engine code stamped in the car unless the block ?and where can i find the ecu code in the car unless on the ecu ?
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 09-03-2006, 06:14 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: engine code places?
Are u talking about trying to find the stock motor and ecu that came in the car? On the ecu, it'll be listed under the barcode (P29, P75, etc). On the block the engine code is on the left side between the block and the tranny.
I know in the US, the vin number contains the motor info as well. The 4th, 5th, and 6th digits represent the body, line and engine type (EH2, EG8, etc) Then if you are not familer with vin codes, you have to figure out what the numbers represent.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 09-04-2006, 03:18 AM
hany's Avatar
i dont mean that. i know the place of the engine code which on the block.and my question is where can i find the engine code else ?
and i know the ecu code stamped at the ecu itself. but my question where can i find it else the ecu ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 09-04-2006, 07:11 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
do you need the stock engine code? what kind of car? model?
-tony-
2000 honda s2000
Old 09-04-2006, 11:00 AM
hany's Avatar
yes the stock and the original orgin code. for honda civic 1993
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 09-04-2006, 12:57 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Neither are printed or stamped anywhere else on the car. Figure out your chassis code, then either do a search online or find a manual for your car. I'm sure it will be a little more difficult, because most of the info online is for either usdm or jdm cars.
Old 09-04-2006, 05:11 PM
hany's Avatar
ok . i will try to search. thanks alot
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 09-04-2006, 05:52 PM
i can find for you tonight.
-tony-
2000 honda s2000
Old 09-04-2006, 10:57 PM
Honda God
As I said before, look at the VIN number, it'll be stamped on the firewall in the engine bay and on the dash and should be on a sticker in the drivers side door jamb. The 4th, 5th, and 6th digits of the VIN number represents the body type, trim line and engine type (EH2, EG8, etc) of the civic. It won't tell you the ECU type, but if you know the engine type it shouldn't be hard to figure out the ecu.
EPR Member 4 Life
Old 09-05-2006, 03:22 AM
hany's Avatar
yes i get it now. it tell me the capacity of the engine and some good info about the car too. thank you alot
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 09-06-2006, 04:05 PM
Honda God
No problem. I'm glad we could help.
EPR Member 4 Life
