Old 08-27-2002, 01:10 AM
triggert triggert is offline
Valve Cover Oil Leak?
I'm looking into getting a VTEC Prelude and I found one with 69k miles I'd like to get but it seems to have an oil leak coming from the lower left part of the valve cover. Could it just be as simple as replacing the valve cover gasket or worse? Could someone give me the worst possibe case and the price it would take to repair it?
Thanks,
William T. Thompson
Old 08-28-2002, 01:01 PM
Tominos Tominos is offline
probably just the gasket. since there is oil under the valve cover all the time, its no big deal.
Old 08-29-2002, 03:02 AM
b16a3sol b16a3sol is offline
sounds to me like the vtec solenoid is leaking. it is a common occurence with any vtec motor. if it is not a lot of oil, then there is no problem. just clean the motor every once in a while and check th oil level. if it looks to be nothing related to the solenoid, then make sure there is not a lot of oil leaking, so you dont have a drop in pressure, or the risk of running low while driving.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 09-02-2002, 11:29 PM
VelocityTrends VelocityTrends is offline
Banned
Just check the gasket if it looks fine just get some goop (Honda (blue) gasket sealer) and goop it up!
goop around cam seals yada yada...
Good luck
www.velocitytrends.com
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
