Old 09-02-2006, 02:52 PM
verv verv is offline
green mean machine {mutant} funny timing problem
Well I finally built my engine and a am getting very impressed with how this new engine is starting to perform. Fisrt of all the cool stuff:
d16a6 block bored .010 over
d16y5 vtec head ported and polished and port matched for the new manufold that I havent built yet
KMS block guard
eagle connection rods
custom ARP main studs
custom ARP head studs
polished crank
p29 pistons (11.5-1)
4-2-1 header
2.5" exhaust
accel 8.0mm wires
solid front and rear motor mounts
0-60 mph time so far is 6 seconds
here are some pictures of the engine and build
now for the question on the distributor i had to notch the nounting holes to get it to time right. I have heard of this before but never paid attention to the cure for this and now i have the some problem. This will only matter for a little bit because i am thinking of going motec4.
Any help would be appreciatted.[IMG][/IMG]
Old 09-02-2006, 03:42 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: green mean machine {mutant} funny timing problem
How do you port match to a manifold you havnt built yet?
Old 09-02-2006, 03:44 PM
Forunn Daberator
Wheres Santa sit at? Do raindeer pull it?
Old 09-02-2006, 03:47 PM
Forunn Daberator
Whats so custom about the head/main studs?
Old 09-02-2006, 03:49 PM
Forunn Daberator
If I bite it does green Jell-o come out?
Old 09-02-2006, 03:51 PM
Forunn Daberator
Guess its time for a real answer. What problems are you having exactly?
Old 09-02-2006, 04:06 PM
Forunn Daberator
By the way, isnt the y5 a "vtec-e" head ?
Old 09-02-2006, 08:57 PM
viper-blue's Avatar
viper-blue viper-blue is offline
6 seconds? Hate to see the embarassed porsches and lambos your leaving at the line
Old 09-02-2006, 09:39 PM
Forunn Daberator
Is there a dead body under your trailer? (bottom left corner, second picture)
Old 09-02-2006, 11:00 PM
viper-blue's Avatar
lmao!
Old 09-03-2006, 11:08 AM
the problem that i am having is that i have had to notch the adjusting bollt holes all the way out just so i can get it into time and it seems that it might be setting the injector timing off. My question is this: is there a way to reset the ignition timing in the computer. I cant move the distributor any further because it wont be able to be bolted up. when i took my car to the track i even saw the same thing done to a lot of hondas there. i am thinking that i still need to retard the timing more but obviously i cant.
Old 09-03-2006, 03:11 PM
Forunn Daberator
Sure your valve timing is right? You shouldnt have move the distributor that much to get it to run good.
Old 09-04-2006, 11:53 PM
yes the valve timing is right
Old 09-05-2006, 12:01 AM
by design
Old 09-08-2006, 04:09 AM
cavalierguy2009 cavalierguy2009 is offline
the cars problem is that it is a honda not a chevrolet
