Go Back   Automotive Forums Car Chat > Ford > Probe
Old 09-02-2006, 02:34 PM
tmarsh tmarsh is offline
Electric Cooling Fan Motor Relay issues...
Today, my wife pulls into the drive and turns off the engine. The fan stays on. I smell burning plastic and look for smoke. I see it in the electric cooling fan relay. I pull the fuse and it stops. Has anyone had this happen before? I pulled it off and it has melted some of the connecter on the car. Is this strictly an electric cooling fan relay problem, or is this the result of something else on the fritz.
FYI - this is the same car that posted problems with it starting approx. 2 wks ago. I fiddled with just about everything including the relay..then it worked. I have know Idea what I did, but I am guessing a short was involved. It seems likely the same problem again, i.e. a short.
Any ideas? Thanks in advance - Aaron
Old 09-02-2006, 10:27 PM
94PROBEGTR's Avatar
94PROBEGTR 94PROBEGTR is offline
Send a message via Yahoo to 94PROBEGTR
Re: Electric Cooling Fan Motor Relay issues...
the best thing todo is have the electrical system checked out. by a pro if possible. someone always parting out. check mx6 or probetalk.com and see if someone will part out the fues box for the engine.
1994 Ford Probe GT
2.5L KLDE V6 24 Valve DOHC ATX
164hp @ 5000 RPM
163,000+ miles and counting....
Old 10-13-2006, 04:05 PM
rhandwor rhandwor is offline
You may have a bad motor pulling to many amps. You could hook up the motor direct and use an ammeter clamp on type. If the amps are high buy a new motor. Check for bad grounds and fix bad wiring.
Old 10-17-2006, 03:43 PM
psgt21 psgt21 is offline
Send a message via Yahoo to psgt21
I have any part you need as far as wiring, relays, fuses, etc. I also have the complete fan assembly. If you need something just e-mail me at [email protected]
