Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-02-2006, 03:14 PM
MikePathfinder2001 MikePathfinder2001 is offline
Need some help with brakes
I have a 97 Blazer and decided to change the brake pads and rotors. The calipers were pretty rusty and I had a hard time getting them off. After I figured out, I cleaned them up and replaced the brakes. I used the old brake pads to push in the pins as far as they would go and then replaced the pads with new duralast pads. Although I thought the pins were in as far as they would go, I still had a hard time getting the newly loaded calipers on the rotors. After putting the tires back on, I noticed that the wheels did not spin freely. The pads seem to be rubbing on the rotor. I have been driving it and there really isn't any brake noise. It seems however, when I hit the breaks and then let off of them and glide slowly, the front right wheel seems to make a rubbing noise and there is a noticable amount of friction and noise. This does not happen all of the time, but seems to occur when it is wet. It almost seems like the caliper gets stuck every once in while. Actually I'm not sure what is going on. What are the common things that a novice can screw up when changing pads. I ask this, because chances are I probably did it. Thanks for the input.
Mike
Old 09-02-2006, 07:13 PM
alblogg's Avatar
alblogg alblogg is offline
Re: Need some help with brakes
Chances are if they was that hard to press in they are having a hard time coming out and in when you put on your brakes. In other words your calipers are sticking or are stuck. Take them back off and check for rust or whatever this time spray some brake cleaner on them and compress them again and see if they go in easier.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 09-03-2006, 06:53 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
At that point he would be better off just buying a couple of loaded calipers. They run about 60 bux a piece at advance. That way he knows he has a good caliper and it comes with frame, pads, new seals, known working and smooth piston(s)
Old 09-04-2006, 02:23 PM
alblogg's Avatar
Yep that's what I would do but you never know if they want to spend money to do it right or are they just doing it to get by.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 02-10-2008, 03:47 PM
Schrade Schrade is offline
Did he have on the top to the fluid reservoir when he tried to press in the pistons??? That doesn't make it any easier...
Old 02-10-2008, 03:53 PM
blazee's Avatar
blazee blazee is offline
Problem?
Please check the dates before posting.
Closed Thread
