Go Back   Automotive Forums Car Chat > Suzuki > Swift
Old 09-02-2006, 12:25 PM
philipdybel philipdybel is offline
94 Swift GA 1.3 - hot start problem
Hi !
I just bought a 1994 Suzuki Swift GA (1.3 liter), with 77,000 miles.
When the engine is cold, it starts right away (within 1 second), and drives great.
After it has run for 10 minutes, sometimes the engine runs a bit rough - like the engine is "missing".
When it's "hot" (after it has run for 10 minutes) and shut off, it will not start:
the engine turns over (compression seems normal), but it does not "fire"; also, every second or so it "backfires" (flames out of throttle body).
When this happens: it seems to have ignition - a screwdriver in the spark plug boot gives a nice spark, although I can't tell if it's timed right. I checked and cleaned the engine grounds. The fuel tank is full. Pouring gas into the throttle body then trying to start it makes no difference. I checked the valve timing (correct) and checked and tensioned the timing belt (good).
After the car has set and cooled for 1/2 to 1 hour, it starts right away.
Has anyone experienced something similar? Any ideas?
Thank you,
Philip Dybel
Old 01-12-2007, 11:31 PM
Honda_12 Honda_12 is offline
Re: 94 Swift GA 1.3 - hot start problem
have u changed your spark plugs and checked if the spark plug wires are in the corect spot???
