Old 09-02-2006, 11:55 AM
soyelmismotony soyelmismotony is offline
2004 chevy silverado 1500
when truck in motion sometimes oil gage shut off and sometimes rmp gage also shut off too. after few minutes if I start truck againg gages work fine. any ideas what to look for...?
Old 09-02-2006, 04:39 PM
obbop's Avatar
obbop obbop is offline
Re: 2004 chevy silverado 1500
Often, with intermittent electrical problems, it's a bad ground.
Not always but seems to be a bad ground more than anything.
Either peek at a schematic to locate all grounds (those whacky Brits call a ground "earth") or poke around and find as many as you can visually. Clean them up with a wire brush. Look for corrosion, it can be hidden inside the insulation especially next to where the ground meets the frame.
Sometimes a wire can rub against an object causing a short, sometime an intermittent short.
Electrical problems are such a pain!!!!!
I'd rather drive a destroyer
Old 09-03-2006, 11:18 AM
Blue Bowtie's Avatar
Registered Offender
When the tachometer and pressure gauge stop indicating, does the engine run normally? If so, I would suspect the problem is at the I/P cluster connectors. You'd have to remove the bezel and I/P to inspect and clean the connectors.
Old 09-04-2006, 11:29 PM
Smile Re: 2004 chevy silverado 1500
yes the engine runs normally I even a travel to another city almost an hour away and the truck run fine
Old 09-10-2006, 01:11 AM
dealer change the cluster and problem solved
