Old 09-02-2006, 09:40 AM
zimgator zimgator is offline
Cool 98 Taurus hazard lights dont work
My 98 Taurus hazard lights dont work but the other lights all work? Could it be a blown fuse?
Old 09-02-2006, 03:32 PM
KimMG KimMG is offline
AF - Advisor
Re: 98 Taurus hazard lights dont work
Bad fuse
bad switch
bad flasher
Use a wiring diagram to map out the circuit and use a meter to test connections and components.
Old 09-03-2006, 12:16 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
On your '98 Taurus, the hazard and turn signals both are activated by the multifunction switch. Both use the same electronic flasher, so if the turn signals work, the flasher module should be okay. The main culprit in this situation is either operator error or a bad multifunction switch.
-Rod
