Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 09-02-2006, 09:34 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Exclamation Gas Tank Vacuum Leak
Okay so my car has had the engine light read and my mechanic advised me that it was a canister that sucked air out of the gas tank at startup. Does anybody know where it is located? He said it was usually black in a smooth cylindrical form usually found in the driver side.
Thanks in Advance,
JoeShmoe
Old 09-02-2006, 10:21 AM
JoeShmoe's Avatar
Question Re: Gas Tank Vacuum Leak
Okay I guys I followed the a hose form the gas tank and found that a hose coming from the tank jsut above where the fuel deposits in had a big gash from a ring clamp. Can you buy jsut that hose?
Old 10-16-2006, 08:45 PM
rhandwor rhandwor is offline
It probably is fuel line hose. Get the size and buy fuel hose for fuel injection. Normally 5/16 inch or 8mm. Take a piece with you. Buy new clamps also.
Old 10-17-2006, 05:23 PM
JoeShmoe's Avatar
Turns out it was a black cylinder towards the rear driver side under the car that was the problem. It was all clogged up and there for didn't function prperly but I got it repalced.
Thanks a lot.
JoeShmoe
