Old 09-02-2006, 08:58 AM
Jonesy02719 Jonesy02719 is offline
Trailer Wire Colors (97 Blazer)
I've tried a search for this, but had no luck.
I am trying to install a wiring harness for my boat trailer, and I need a description of the wires coming out of the rear harness. I have a 97 Blazer LT with an OEM towing package.
As far as I recollect, there's a blue, red, brown, yellow, dark green, lighter green, a larger white and a smaller white wire in the harness.
Another previous owner obviously had messed with the harness, since some of the wires are different lengths. I have no idea what wires are which, since there is no decal or anything that tell me any descriptions. Also, I do not have an owners manual for Blazer.
I tried hooking it up, but I keep blowing my 20amp brake/hazard fuse. I only blow the fuse when the trailer is hooked up. The two different white wires, and the two different green wires are my problems...
Can anyone post a description of all thge wire colors?
Old 09-02-2006, 09:36 AM
Blue Bowtie's Avatar
Registered Offender
Re: Trailer Wire Colors (97 Blazer)
The typical lighting colors for most GM vehiles dating back to the 1950s (your '97 Blazer included) is as follows:
Yellow - Left Turn/Brake lamp on all years;
Dark Green - Right Turn/Brake lamp on all years;
Brown - Tail/Marker lamps on all years;
White - Chassis ground on early vehicles, Center brake lamp on 1986-up vehicles. In your case, the larger white is PROBABLY the ground, and the smaller white is PROBABLY the third brake lamp;
Light Green - Back Up lamps, which may or may not be used on your trailer lighting;
The blue and red wires are not factory lighting. They may be from a brake controller or some other device.
Old 09-03-2006, 11:57 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Originally Posted by Jonesy02719
. . . previous owner obviously had messed with the harness, since some of the wires are different lengths. I have no idea what wires are which, since there is no decal or anything that tell me any descriptions. . .
Since the wires have been messed with, the color may not mean much, thus I would suggest using a test light to determine what wire is controlled by what. If your trailer is not new, you might want to use a fused 12V jumper wire to see what is what on the trailer also.
Old 09-03-2006, 10:49 PM
DelCoch's Avatar
Maybe these photos will help
Old 09-04-2006, 10:57 AM
Cruize Cruize is offline
It's been a couple years since I worked with trailer wiring, but I would venture a guess that the red wire could be a dedicated wire for charging a wet cell battery on a trailer (RV).
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
