Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-02-2006, 08:34 AM
pickjackson pickjackson is offline
1997 ford thunderbird
Good Am window drivers side starting to shutter when i put it up etc...is it coming off track or does it need some lube somehow? thanks
Old 09-04-2006, 02:37 PM
justmount1 justmount1 is offline
Re: 1997 ford thunderbird
should just need some lube.
Old 09-04-2006, 04:52 PM
thanks for response but how u lube it?
Old 09-04-2006, 05:50 PM
take the door panel off and lube it on the window trac where it goes sideways
Old 09-04-2006, 07:14 PM
97Bird's Avatar
97Bird 97Bird is offline
Get a can of silicone spray, lower the window and then spray into the window channel. Raising and lowering the window a few times after you spray should distribute the silicone. You may have to spray a few times. Try this first before you go through the trouble of removing the door panel.
The Original 97Bird
Old 09-04-2006, 07:22 PM
G-man422's Avatar
G-man422 G-man422 is offline
^ I'm no expert, but i think that could just cause more of a headache.
Old 09-05-2006, 09:19 AM
97Bird's Avatar
To each his own. I've never had a problem with it.
The Original 97Bird
Old 10-28-2007, 12:36 PM
97 thunderbird boiling over
Have 97 t bird, boils over, engine hot, temp gauge is normal and not check engine light comes on any ideas cause? am a starting a new ? thread right?
Old 10-28-2007, 07:42 PM
rhandwor rhandwor is offline
Start by checking if the fans are running properly. Then check both the top and bottom radiator hoses are hot indicating flow thru the radiator.
You could have a blown head gasket as the gages show normal temp. I would go to a radiator shop and get a gas analysis before you damage the engine.
Old 10-29-2007, 01:20 PM
thanks for info, i drove up to store this am and heat gauge when mid way etc. and then it went back down a bit then went up to half way...when go to store checked under hood hose out of radiatior was hot, did not check bottom as could not get hand down there plus was at store seemed fine and perhaps did not drive it long enough to see if it was still going to be a problem...could this be some thermostat issue? thanks
Old 10-29-2007, 03:48 PM
It could be thats why you need to feel the top and bottom hose. A closed thermostat or a plugged radiator can cause this or a collapsed hose.
Old 10-30-2007, 07:55 AM
so should both hoses be hot then? or cold?
Old 10-30-2007, 08:09 AM
If the car is up to operating temperature they both should be hot to the touch.
