Old 09-02-2006, 01:34 AM
alex.w *// alex.w *// is offline
92 dodge caravan headlight problem
when i was driving, it got dark, so i turned on my lights, but after when i got home i turned off the lights. Every light turned off except the headlight. On the dashboard the blue highbeam signal lamp was on, and I wasnt even on highbeam. The blue highbeam signal never turned off. Now when I drive i have to plug the headlight socket in for the lights to turn on, and when i turn off the car i take out the socket to the headlights.
I was thinking it hs something to do with the light switch or possibly the relay switch. If any one knows how to fix this problem, please help. or tell me where the relay or headlight switch is located.
thanks
Old 09-02-2006, 02:21 AM
KimMG KimMG is offline
AF - Advisor
Re: 92 dodge caravan headlight problem
Sounds like the flash to pass position of the stalk switch is in a stuck closed position. May have to replace the switch.
Old 09-05-2006, 05:21 AM
imamacanac imamacanac is offline
Send a message via MSN to imamacanac
thanks
sounds more like the daytime running light module. It's located on the firewall on the passenger side. It's black in color, and is square in shape. try unplugging it, to see if the lights turn off. I recently had the same problem on my 93 Voyager.
Old 07-04-2011, 09:55 PM
rainandsun rainandsun is offline
same issue i got from my dodge caravan. what i just did is i unplugged the cables. and that is the Dodge Caravan repair to fix that issue.
