Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 09-01-2006, 08:36 PM
wildbuzz wildbuzz is offline
02 Envoy Evap Emission Control problem
Engine light came on and the code stated P0440- Evaporative Emission Control System malfunction. It has something to do with the charcoal canister. How much and is it easy to change the canister on my own?
Thanks
Buzz:
Old 09-02-2006, 08:13 AM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: 02 Envoy Evap Emission Control problem
Thanks
Buzz:
Stop!, this does not mean the cannister is bad it is a system malfunction, try tightening your gas cap first then addt'l diagnosis is required. This is not a dyer type repair until the problem is pinpointed, that may require a full scan and possible use of a smoke machine to find the leak/malfunction.
Old 09-02-2006, 11:02 AM
benihana benihana is offline
OK, this is weird. I'm having that problem too. Mechanic recommended buying a new gas cap and I did, and check engine light came back on....
Old 09-02-2006, 02:21 PM
A990 racer
Lightbulb Re: 02 Envoy Evap Emission Control problem
That is beacuse that was not the problem, further diagnosis is necessary a mentioned above.
Old 09-09-2006, 11:18 AM
rodeo02 rodeo02 is offline
If the gas cap doesn't fix it, further troubleshooting is needed. Could be the purge solenoid or an associated tubing leak. There is a very basic EVAP system schematic sticker under the hood. The vacuum source for the 4.2L evap system is right up front/top on the throttle body.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
