Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-01-2006, 08:25 PM
airFS airFS is offline
Exclamation Dont know whats going on
Well what's been going on has been happening for a little while now. Sometimes whenever I'm just crusing along and decide to step on it or even when I'm just accelerating something seems to hold back my car and I have no idea what it is. I can hear the turbo start to spool up then when I expect it to throw me back in the seat a litte (t-25) it dosent. It actually throws me foward a little, but that just may be because I was ready for the turbo hit. I can see the needle on the spedo go up but it feels like the car stays the same speed. This happens somewhat often like once every 2-3 days so I dont know if this could become major.
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 09-01-2006, 08:32 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Dont know whats going on
I had this happen to my Talon on a rare occassion. I never was able to figure out what it was though. I assumed the clutch was slipping some or something to that effect. The stock clutches suck bad on these.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-01-2006, 08:41 PM
that could be it because my clutch pedal it quite soft but am still open to other possibilties
96' Talon tsi AWD
Old 09-01-2006, 08:55 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
The clutch usually smells pretty bad when it slips especially that badly. It's a fairly distinct burning smell so you should notice it (even if your windows were up)Do you rpms go up but the speedo doesn't? If so then it's definetely your clutch. If you have the stock clutch i wouild replace that in the near future...
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-01-2006, 08:59 PM
pretend everything is normal, except the car isn't pulling... The RPM's Speedometor, the turbo spools, you hear the bov. Everything works properly except the car has zero pull to it... I know what burning clutch smells like and I could never smell it. It would happen whenever I was driving the car normal. Not after beating on it or anything. It was quite a strange problem but I never had it again after my new clutch was put in. Hence the reason I thought it was the clutch slipping due to old age.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-01-2006, 09:02 PM
ok then it probably isnt the cluth now that you mension it. It seems almost like back pressure because whenever it happens i just lift off the throttle and that normally seems stop the problem and my bov makes the sound it makes whenever it's at full boost(which i dont think it would be at) and the speedo says I'am accelerating but it dosent feel like I am
96' Talon tsi AWD
Old 09-01-2006, 09:04 PM
^"zero pull" are the best words to describe it
96' Talon tsi AWD
Old 09-01-2006, 09:09 PM
ez1286's Avatar
Has it gotten progressively worse? Generally when clutches go bad they get worse and worse.
Old 09-01-2006, 09:20 PM
Eventhough its been going on it hasnt gotten noticably worse
96' Talon tsi AWD
Old 09-01-2006, 09:27 PM
ez1286's Avatar
On the two burned clutches i've experienced (my brother's 2g, and his 93 240sx) both got a lot worse after each time it slipped, and both smelled horrible.
Old 09-01-2006, 09:35 PM
I've never smelled anything yet and I almost always drive with my windows down and havent had any major slipping yet either
96' Talon tsi AWD
Old 09-01-2006, 10:46 PM
ez1286's Avatar
I say get a new clutch cause it still could be the problem (crow said his never smelled) plus you have awd and you need to know the feeling of dumping the clutch at 5k rpms!!
Old 09-01-2006, 10:48 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I am thinking cluth too. I dont think that it always smells when its burning. I did a hard launch (5500 dump, not even a quick let off, basically had the clutch floored and moved my foot over and let the pedal come up by itself). After the pull (1-3) I had to stop for a stop sign. It smelled uber bad then, the 6-7 blocks home, and it was still smoking when we were looking to see what was burning. I dont think I should suggest this, but to see if it is your clutch, you could do what I did. In doing this you could also just fuck something up that isnt. Anyway, my vote is for the clutch.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-01-2006, 11:30 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
I had this same exact problem and it would also only happen when I was just daily driving it not beating it. The RPMS would tach up but the car would not go anywhere. Also when I would let off the gas then hit it again it would respond right away. I have not had this problem to my knowledge since my clutch was replaced. I did not smell any burnt clutch either when this happened, and believe me I know what burnt clutch smells like.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 09-02-2006, 09:40 AM
Alright you guys have me convinced i need a new clutch
96' Talon tsi AWD
