battery
ok so i just hooked up a new amp and sub and now the car battery dies after the car sets over night why would this be i thaught maybe it was that the amp wasnt shutting off but it is so i have no clue why
Re: battery
Do you have a capacitor installed? And if so, is that turning off?
Rusting out Honda Civic $900 Fart cannon muffler: $300 Assorted stickers advertising products you'll never own: $50 Having your @ss handed to you by a brick shaped suv: Priceless. Yup, I own the suv. |
Re: battery
Re: battery
Are you sure you have the remote wire hooked up correctly. If you have it hooked up to a constant 12v wire, then the amp will constantly be on. Make sure you have it hooked up to the accessory wire. Your amp should have come with some sort of install guide that should help you out a little better. Also, you are using it with an aftermarket radio right?
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
Re: battery
since the +12v is coming straight from the battery, make sure youre not shorting anything out.. if it is, theres your problem..
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
Re: battery
yea its hooked to the accessory wire and no on the capacitor and yes on aftermarket radio.
Re: battery
Try disconnecting the amp overnight and check results. Play w/ the pos. wire in a dark garage and see if there is a spark when its connected. My 96 will die when in harsh winter and sits for 3 or 4 days w/ a brand new battery and alternator.
Re: battery
that was happening with me so i just wired everything to a switch in between my cup holder solved the problem and not hard to do at all.
Re: battery
better be a huge switch (unless you used it on the remote..)
