Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 09-01-2006, 05:42 PM
buyllc buyllc is offline
Exclamation 96 Jetta DTC error code P1613
My check engine light come on this week; after a scan the DTC reported a P1613 error. I searched the web for this error and found this:
MIL Call-up Circ Open/Short to B+
Does anyone know what componet this refers to? Has anyone seen this error with their Jetta? Thanks in advance for any help, or insight you can give.
buyllc
Old 09-11-2006, 03:13 PM
Doug Tatham Doug Tatham is offline
Re: 96 Jetta DTC error code P1613
MIL = malfunction indicatory light
The circuit between the computer and the light has an open or short to B+ (battery postive terminal).
Old 06-12-2009, 07:59 PM
Thank you for the help. Your help solved the problem for us.
Old 10-29-2013, 08:15 AM
racole1980 racole1980 is offline
i have the same code in my jetta.how do you fix this and wich "light" are you refering to?
Old 10-29-2013, 10:58 AM
65comet's Avatar
65comet 65comet is offline
Check your grounds and wiring. This is a CEL (Check Engine Light) code for when the CEL itself is having a problem. Could be the CEL bulb is burned out.
Here are some other possibilities.
- an automatic transmission ECU was installed at some point (car is manual, I recently purchased and don't have much service history). Beleiving there is an auto tranny, the MIL comes on because it does not detect auto tranny ODBII sensors. A Vag-Com needs to be used to update ECU Firmware.
- "the issue was the bolt holding in the crank position censor wasn't in tight enough, so the ecu wasn't getting any info back from the sensor, resulting in the code." Solution: plug in sensor
- There is a grounded wire between ECU and MIL. Cluster needs to be removed and wires tested for ground.
The Following User Says Thank You to 65comet For This Useful Post:
racole1980 (10-30-2013)
