Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 09-01-2006, 04:54 PM
IntegrityCaptain90 IntegrityCaptain90 is offline
In need of a good faq.
Im replacing two injectors in my 1996 3100 beretta. i have intake manifold loose but before i seperate my fuel rail i need a step by step on how to re-install correctly. can anyone help me out???
Old 09-04-2006, 08:33 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: In need of a good faq.
I assume you relieved fuel pressure by pressing the schrader valve until no fule comes out. Once the upper plenum is off, there are bolts that hold the fuel rail in the lower intake manifold (LIM). Remove these bolts and gently rock the fuel rail to loosen the injector o-rings from the LIM. I strongly suggest replacing all of the injector o-rings, not just those on the injectors you're replacing to avoid possible fuel leaks. Coat the injector o-rings with clean motor oil and they should just slip in place.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
