Old 09-01-2006, 04:43 PM
thinmints thinmints is offline
96 XJ hub replacement
im going to replace my wheel hubs just was wanting to know if there is a tool that i need to get or can i just use a hammer?
Old 09-03-2006, 08:26 PM
gtmud gtmud is offline
Re: 96 XJ hub replacement
You will need and Impact gun and compressor and I believe a 36mm socket to get the axle nut loose, and torque wrench that goes to 200 ft. lbs( axle nut is torqued to 120 ft lbs ( I think) and the bearing hub bolts are torqued to 75 ft. lbs. Good luck.
