Go Back   Automotive Forums Car Chat > Lotus | Proton > Europa S
Old 09-01-2006, 11:47 AM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
Test post
Joe Cipriano 1:00
31 August
1.Tire functions are as follows ~ They cushion the vehicle ride to provide
comfort to the driver/occupant. Firmly support vehicle weight. Develop
traction to give the drive stability and steering on the road & Directional
stability.
2. The tire bead itself shapes the wheel and allows a stable fitting. The tire
bead filler acts as a reinforcement for the side wall and acts as a rim
extender.
3.The antioxidants prevent harmfull wear on the tire from things like UV light
and prevents harmfull gases from escaping.
4. The steel belts on a radial run across each other in an overlapping pattern
to provide maxium strength and comfort.
Bias-plys, Ply's run along next to each other and create warp over time and
are not very efficent.
5. The advatages of an all season tire are that it has more gap on the road
so less wear on the tire and longer life. It also is more stable in bad
conditions.
6. A "B" load rating is meant to carry less weight then a "D" load rating which
is for light trucks.
7.An "A" tire temp rating is alot higher and can with stand greater friction
temperatures then a "C" which is considered acceptable.
8.The tire contact area is where the "rubber meets the road" and traction is
applyed. Tire deflection is Tire deflection is the difference of the free
diameter and the rolling diameter of the tire.
9. A rim drop makes changing the tire alot easier and quicker. The saftey
ridges are there to prevent tire beads from moving into the center of the rim.
10. Static unbalance is when the rim/wheels rotational mass is effected by
being throw off center, which in turn effects the centrifical force of the
wheel.
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
