Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 09-01-2006, 12:46 AM
sherlok sherlok is offline
Arrow More idle problems
Hi, my 89 pulsar has had some idling troubles..it was idling high (1100) after a cold start, then later warm idlingwould wander from 600 to 900. It started running quite rough when idle+accelerating, with a distinct smell of unburnt gas. I took off the throttle body and cleaned that mess up, and checked the airfilter. Got it to run a bit better, but now has very low idle, at 5 or 600 or a high idle at 1600. what to do now..
thanks for any help
Old 09-02-2006, 05:06 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: More idle problems
Need to find the Idle Air Control Valve(IACV) and clean it out. Known to suck dirt/oil into it and suck in too much air and the ECU tries to compensate... badly. Very common problem.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 09-02-2006, 04:49 PM
Is the AICV the black thing on the right side of the throttlebody??
thx for the reply
Old 09-03-2006, 08:20 AM
mmcleo11's Avatar
Yes, it is usually black and normally has a thin rubber pipe that goes to the wider rubber intake pipe which connects to the air filter.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
