Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 08-31-2006, 09:48 PM
pyr0maniac pyr0maniac is offline
Running Temp
I was riding in my friends JGC the other day and noticed his running temp was way lower than mine, mine is around 215 and his was in the 100s, is this normal for my jeep? 2000 JGC I6 4.0L
Old 08-31-2006, 10:41 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: Running Temp
Your friend should change the t-stat. It is probably stuck open and will eventually slip closed and cause the engine to over heat. Both gauges should read 200 degrees.
Old 08-31-2006, 10:55 PM
Ron68 Ron68 is offline
Re: Running Temp
Before you change the stat - check to make sure that you have a good indicating system. Check the temp at the coolant reservoir (carefully bleed the pressure off first) when up to temp with a thermometer (candy, espresso, meat, etc) to make sure you don't have a bad temp sender or gauge. You should be reading 195 degrees for a 4.0L.
2004 Grand Cherokee Overland (DD)
2000 Ford Explorer (Daughter's ride)
1986 Ford F-150 ( Ridge Runner)
2002 Mercury Mountaineer (Mama's ride)
1968 Ford Mustang Coupe (modified a little)
"If it ain't broke, then don't fix it."
Old 09-01-2006, 06:28 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Running Temp
Your friend could have a cooler t-stat in his jeep. I am currently running at 150 degrees (I run a 160 degree t-stat).
Alot of people say that the normal operating temp of a jeep is around 210, yea seems normal - but the t-stat is 195 so it should open and close around 195, mine used to be around 210 on the highway then in city driving would go up to 235 - then my radiator side tank blew out and when I replaced the radiator my temp around town immediately dropped to 180 degrees.
