Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-31-2006, 09:38 PM
ffgus ffgus is offline
97 monte 3.1L
My 97 monte keeps stalling. It starts, but it seems the idle is "searching". From 800 RPM to 500 RPM. When driving, rolling to a stop, it will hesitate, then quit. New injectors 1000 miles ago...Reform gas in Milwaukee, WI.
Only 53000 miles...
Gus...
Old 08-31-2006, 09:57 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: 97 monte 3.1L
Replace your Ignition control module.
Tell me how it goes.
Old 09-01-2006, 12:56 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 monte 3.1L
Try removing the IAC valve from the throttle body and cleaning the pintle and the bore it rides in
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-01-2006, 07:44 PM
Re: 97 monte 3.1L
Where is this idle air control valve located? Do I need a replacement gasket right away or can I use the old one? What type of cleaning solution can I use?
Thanks...
Old 09-04-2006, 08:54 AM
richtazz's Avatar
Re: 97 monte 3.1L
The IAC vavle is in the throttle body. It is mounted to the TB with 2 screws. There are basicall two sensors ont the TB. One is the TPS (throttle position sensor) and the other is the IAC. When you unbolt the IAC, you will see a cone shaped pintle with a spring behind it. The best cleaner to use is Throttle body cleaner, but Carb cleaner will work in a pinch. Just make sure you let it evaporate before attempting to re-start.
