Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-31-2006, 08:48 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
420a bottom pully
i used the special chrysler puller and everything but its not quite long enuff. its still pressed on about 1/4 of an inch if that and i cant get it off for shit i've pried and pried. anyone else ever ran into this problem and if so how the hell did you get it off
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 08-31-2006, 08:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 420a bottom pully
I have this problem every time I pull it off. What I end up doing is threading in a longer bolt into the hole that sticks out like 1/2" or so and then use the puller. I never use the special chrysler one though so I'm not sure exactly how it works, but if it's like any other puller you should have no problem with using a longer bolt.
95 Talon TSI AWD
97 Eclipse GST
Old 09-10-2006, 11:03 AM
shelnick shelnick is offline
have a 95 eclipse - have had my pulley off several times - I put a center punch I have shortened into the bolt hole of the crank and as the top of the punch is square, I put a socket on the end so the threaded bolt from the pulley goes into the socket and it will not try to slide off. this will allow you to get additional leverage to get it off. I use a 3 jaw craftsman puller.
hope this helps
Old 09-10-2006, 11:17 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Ok heres how i did it, I got a piece of a metal rod, 1/4in i think and cut several different sizes and slide them in where the bolt goes so not only was i using the threads to push against but the rod too and when the threads wouldn't reach i just pushed against the rod.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-11-2006, 11:26 AM
1996EclipseRS 1996EclipseRS is offline
I broke about 6 pullers to get mine off. Fun stuff.
420A
JE Forged Pistons 10:5, Crane Super Street Performance Cams, Crower Connecting Rods, Crower Valve Springs, Port & Polished Head, A'PEXi SAFC II, DigiMoto Datalogger + more, Prothane Motor Mounts, Ebay Header =(, Stock Exhaust, busted driver side window, stolen SAFC(tear), blown tranny
-1984 Mercedes Turbo Diesel 300CD (270k)
-1992 Ford F-150 302 (180k)
