Old 08-31-2006, 08:37 PM
mike_flemming mike_flemming is offline
engine cleaning?
The engine bay of my 95 lumina is..well less then clean. The car as apparently been undercoated twice and theres a ot of grease and grime in there. any thoughts about a good way to clean it??
Old 08-31-2006, 11:09 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: engine cleaning?
i've heard good things about Simple Green, never have used it though. Steam cleaning always does a good job. When spraying it, try to stay away from the alternator, coil packs, and PCM in the plastic case under the radiator resivior. Other than that everything else under there is fair game.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-01-2006, 06:37 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
I have a similar question. What is a good degreaser/cleaner to use on the engine cover where it says "3.1 Multi Port FI" (On my '93 of course). I was wondering if a brake cleaner would do the trick.
This ain't your grandma's car!!
Old 09-01-2006, 06:55 PM
Blue Bowtie's Avatar
Registered Offender
I use hot water from a garden hose, laundry detergent, a stiff brush, and degreaser where necessary. I don;t worry about wires, connectors, coils, and whatnot. If it can't take clean water, it probably won;t take road spray. I've started with soem fairly nasty engine compartments, and it usually does an adequate job:
Old 09-01-2006, 07:03 PM
gw84's Avatar
Boy, that 3800 series II (plastic?) cover in my '99 LTZ is super easy to clean compared to the 3100's. Thanks for the input! BTW, this is a totally different subject but: I noticed that my mechanic filled the cooland resovoir up about 8-10 inches above the HOT line. Could this be a problem. It's just an overflow tank isn't it?
Old 09-01-2006, 08:01 PM
Registered Offender
On a '95, it's simply overflow recovery. In later years, it may be an expansion tank in some W-body cars.
Old 09-04-2006, 07:21 PM
gw84's Avatar
should I try to remove some of the coolant in my reservoir? The level is quite high, even when cool (the is still some room at the top of the tank for overflow)
