Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 08-31-2006, 02:42 PM
mdshumaker mdshumaker is offline
expensive rivet tool options
Hey all,
I've got a '91 Mustang LX. The power door lock actuator rivet has broken.
I've gotten this big ol' rivet (T-rivet)from my local Ford parts department, but it's too big for my little hand riveter. I've done some online searching and found that a proper tool to do this is $40-$50. (it's a 1/4" rivet)
Is buying and $50 tool to install one rivet my only option??
Marc
Old 09-05-2006, 01:20 PM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Re: expensive rivet tool options
Check your local equipment rental stores where you can rent power equipment. A lot of them also rent hand tools that are specialty tools for a reasonable rate.
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 09-08-2006, 10:47 AM
directory's Avatar
directory directory is offline
renting odd/ one off tools is the way to go. its a lot cheaper (and space saving). i know of the rivets you are talking about. a friend of mine had to rent the rivet tool when the same rivets broker in his cougar.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 09-08-2006, 12:42 PM
KimMG KimMG is offline
AF - Advisor
I was unable to locate the rivet tool in question for the window regulator in my Ford. I ended up using 6mm nuts and bolts with locktite.
Old 02-28-2007, 12:51 AM
smurfmobile smurfmobile is offline
go to the shop portion of just about any body shop and ask anybody around a toolbox if they have a rivit gun that will fit the rivit. i give freebies all the time, if for no other reason than pissing off the boss.
Old 03-06-2007, 07:50 PM
flybynight flybynight is offline
shouldn't be that hard to find any major tool distributor should have it even your local autozone should be able to rent you one for whatever it costs to buy it and then when you return it they'll give you all your money back
