Old 08-26-2002, 01:51 PM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
Question 90 Civic DX HB Oil Pan REmoval
Hi all. I just bought a 90 civic and the oil pan bolt is leaking oil. I bought a new oilpan and want to install it. I can get about 11 bolts off, but the ones toward the drivers side are kinda hidden. Does anyone know the propper way of removing the oil pan in order to replace it?
Thanks
Scott
Old 08-26-2002, 01:54 PM
Whitey001 Whitey001 is offline
sorry wish i knew whats in the way?:badass:
Old 08-26-2002, 02:26 PM
GTA's Avatar
GTA GTA is offline
Whee..
is it just the drian bolt thats leaking? Mine did, buts thats only cause i didnt replace the Drain plug gasket when i didi an oil change. I woudl try changing that first.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 08-26-2002, 02:30 PM
Is this gasket you are speaking of the same as a washer?
Old 08-26-2002, 02:57 PM
GTA's Avatar
GTA GTA is offline
Whee..
its actually a bronze washer if i remember correctly, but they call it the drain plug gasket.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 08-26-2002, 06:35 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
my plug was leaking because I stripped the bolt so I tried to remove the oil pan and get a new one but i couldnt get all the bolts off so i took it to a garage and they just put a new plug on for $50
blah
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
