Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 08-31-2006, 12:31 PM
cosika cosika is offline
turn signal problems
My fiance has a '90 Baretta and her turn signals don't work, also her emergency lights only work in the front, but not the rear. Any suggestions on what may be the cause and how to fix it?
My sister's husband tried switching the turn signal module with the emergency module, but that didn't do anything.
Old 08-31-2006, 02:28 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: turn signal problems
When you say they don't work, do they not flash or not come on at all? Assuming that you have already checked the bulbs and fuses, (and assuming they don't come on at all) check for power to the sockets. If no power at the socket, check further up the wire until you find power. If you have power to the socket, make sure the ground is good.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-31-2006, 03:00 PM
Blue Bowtie's Avatar
Registered Offender
You have eliminated the flashers as a problem by switching them, so you should check the fuse for the turn signals (it is separate from the hazard flasher fuse).
If the fuse is intact, I'd suspect a problem with the brake lamp switch, the 4-way hazard switch, or wiring. Of those three, it would most likely be the switch.
Do the brake lamps work correctly? Including the center high-mounted lamp?
One thing you can do is exercise the 4-way hazard switch on and off for several cycles to help wipe the switch contacts. The turn signals operate through the normally closed contacts of this switch. The outer (not the center) brake lamps also route through this switch as well, so if they fail it is an indication that the hazard/turn signal switch is failing.
