Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 08-31-2006, 10:17 AM
TonyLS TonyLS is offline
gear/shift indicator light
The gear/shift indicator light is out for all gears. Can this bulb(s) easily be replaced? Is it just one builb or many?
Thanks
Old 08-31-2006, 01:18 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: gear/shift indicator light
What year is your LS, and does it have the Select Shift Transmission? I don't think V-6 or V-8 matters, but it is still a good idea to include that info as well.
-Rod
Old 08-31-2006, 02:35 PM
It's an 04V6, doesn't have a select shift
Old 08-31-2006, 04:47 PM
shorod's Avatar
SHO No Mo
Try to access the bulb by removing the trim panel over the gear shift lever. Per the service manual for the 2004, this involves:
  1. Pull upward from the front of the trim panel to release the retainers.
  2. Disconnect the electrical connectors.
If you cannot reach the bulb holders from there, then you will need to remove the center console assembly. For those instructions, send me a private message with an e-mail address for you that can accept attachments.
-Rod
Old 09-11-2006, 07:52 PM
listenloud listenloud is offline
I have a 2000 with select shift and a burt out bulb. What is the process with this set-up?
Thanks,
Old 09-11-2006, 09:35 PM
shorod's Avatar
SHO No Mo
  1. Apply the parking brake.
  2. If equipped with a manual transmission, place the selector lever in fourth gear.
  3. If equipped with an automatic transmission, place the selector lever in neutral.
  4. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  5. Remove the ashtray finish panel.
    • Disconnect the electrical connectors.
  6. If equipped with a manual transmission, remove the gearshift lever knob.
  7. If equipped, disconnect the cellular phone electrical connectors.
  8. Remove the console finish panel assembly by pulling upward from the front first.
    • If equipped, disconnect the traction control switch electrical connector.
    • If equipped, release the cellular phone wiring harness from the console finish panel assembly.
  9. To install, reverse the removal procedure.
-Rod
