Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-31-2006, 12:55 AM
homeskillet43 homeskillet43 is offline
Send a message via AIM to homeskillet43
Lower Control Arm Bushing Removal
I was wondering if anyone had any info on how to replace the lower control arm bushings on a 1996 Lincoln Town Car? My are squeaking a little too, sounds like someone is jumping up and down on a old coil mattress. If you have any info please let me know.
Old 09-07-2006, 12:58 AM
Towncar's Avatar
Towncar Towncar is offline
Re: Lower Control Arm Bushing Removal
Didn't I send you a Service Manual on CD? It's all in there.
-Steven
1996 Town Car, Cartier
Old 09-07-2006, 12:21 PM
Re: Lower Control Bushing Removal
u never sent me a service manual.
Old 09-08-2006, 02:20 AM
Towncar's Avatar
MY BAD, I APOLOGIZE
Get a mailing address to me and I'll send the CD's right away. PM works fine.
-Steven
Old 09-10-2006, 01:42 AM
Towncar's Avatar
I pulled the Control Arms, and Stabilizer Bar sections from the service manual to PDF ready for email is that's all you need right now.
PM me an email to send the PDF's to.
I also sent you a PM re. the software for Ford Service.
-Steven
Old 11-01-2007, 11:04 AM
Yanqui Yanqui is offline
Hello, did you ever fix the noise? i am having the same problem.
Old 11-04-2007, 01:30 AM
cocotel cocotel is offline
That sqweek is usually the upper or lower bushings. And the upper took a press to replace for me. A good way to find out for sure is to take it for a free estimate at a reputable shop. You might be able to see cracks in the bushing if you look close. if you have a press and the other tools it is no big deal, if not you might be better off to hire out the ball joints and control arm bushings. A buddy did it with out the press and bent the hell out of the ends where he pounded the bushings in place. If you go this route use a socket or two to keep that end from bending.
Old 11-05-2007, 02:14 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
You need to be careful pressing these bushings out. The rear control arms are just thin stamped pieces, very easy to bend. If any one needs any. I have a good rear set upper and lowers with good bushings. [email protected]
Mike
