Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-30-2006, 10:13 PM
performance06 performance06 is offline
help-sierra 1500 will turn over but won't start
the truck turns over but wont' start, we've checked and replaced the fuel pump and fuel filter. the fuel pump doesn't turn on unless the relay is bypassed but still no gas is getting to the engine. i can't figure out whats wrong. also we switched the relays around and checked them but it didn't help
Old 08-31-2006, 12:54 AM
2000CAYukon 2000CAYukon is offline
Re: help-sierra 1500 will turn over but won't start
What year? Engine?
//2000CAYukon
Old 08-31-2006, 07:05 PM
1990, i think its a 305 v8. 5.0, 5.7L?
Old 08-31-2006, 07:32 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: help-sierra 1500 will turn over but won't start
Ok, you have fuel pressure, right, by bypassing the relay, do you have injector pulse and or/spark, the injectors also have fuses remember if no pulse at the injector plugs. See if it starts with carb cleaner sprayed into the TBI to confirm it is solely a fuel problem, all of this is basic diagnostics.
Old 09-01-2006, 12:34 AM
Looking at the factory manuals for 90, a bad oil pressure switch can cause the pump to not get power.
//2000CAYukon
Old 09-02-2006, 04:12 AM
Also I tried to use a Snap-On computer to do a diagnostic check and that did not work. It couldn't connect to it or something
Old 09-13-2006, 07:11 PM
So now its running I took my chances and bought a new EMC, threw it in and it started up. Passed air care, got insurance, than a 24hr suspension. ....
Old 09-24-2006, 12:03 AM
navyordie navyordie is offline
I have a 1982 GMC Sierra, V-8, 305, with a rodchestor quadra jet carborator that has done the same thing. was running fine then all of a sudden wont start. replaced: spark plugs, spark plug wires, coil, modulator, modulator pig tail, distributor cap. mine still wont start. any ideas?
Old 09-24-2006, 10:36 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
navyordie you should start your own post...you will get better responce.
