Old 08-30-2006, 06:39 PM
Gordon Bombay Gordon Bombay is offline
transmission help plz!
i have a 1992 Ford Taurus SHO and i was at my work the other day replacing most of the fluids and i was about to change my manual transmission fluid also but couldnt find the dip stick or the pan underneath the car itself, now im wondering if the car even has tranny fluid...i would think so but if anyone knows if there is one could they let me kno in or around what general area it would be in, that would be a great help for me thanks =)
Old 08-31-2006, 12:02 AM
brokenantimatter brokenantimatter is offline
Re: transmission help plz!
If you are seriously questioning the fact if your car has tranny fuild or not, I suggest you leave because you shouldn't even be opening your hood let alone attempting to change or touching anything that is a moving part.
As for the SHO the dip stick is located under the hood, most likely near the brakefluid resvoir. (right side of the engine bay towards the firewall).
There will either be a plug in the tranny pan or you will be required to remove the transmission pan all together.
Old 08-31-2006, 07:05 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Since you mention that your SHO has the manual transmission, you probably won't find a dipstick or a pan. Many manual transmissions do not have either. Instead, you will have a drain plug low on the transmission housing and a fill plug, very similar in size to the drain, a few inches higher on the transmission.
Before removing the drain plug, make sure you can find the fill plug and can get it loose. You don't want to drain the fluid only to find you cannot get the fill plug loose!
Check the manual and make sure you fill the transmission with the proper fluid.
-Rod
Old 08-31-2006, 10:33 AM
Millermagic Millermagic is offline
You'll laugh, but I actually got in an argument about that one ...
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
