Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-30-2006, 05:58 PM
grandmarquisguy grandmarquisguy is offline
Unhappy Need New Engine
I Need A New Engine For My 92 Grand Marquis..... But I Dont Want A Grand Marquis Engine. So My Question Is Can I Fit A Maurader Engine In It Or A Newer Year Engine.
Old 08-31-2006, 10:44 AM
BiggerJon BiggerJon is offline
Re: Need New Engine
an old friend of mine put a marauder engine in his 92 vic. it took a LOT of modding and fabrication. it took over a year to finish and it was worked on every day by his father(who was a mechanic). when done it ran like a raped ape!
then he started to have problems with it and i haven't heard from him since.
92's are a goofy year of panthers. they had 2 different trannies depending on when they were built. an aod or an aode. if you have an aod you can put a 5.0l in your car if you like.
no matter what you do it will only be cost efficient if you get a used engine for install. if you are not doing the work yourself, it will be cheaper to get another panther.
good luck.
what is the matter with the engine to make you think you need a new one?
Mods
Old 09-01-2006, 12:13 PM
Re: Need New Engine
nothing wrong with it. its got 164,000 miles and needs a quart of oil every 500 miles but thats it nothing to bad. i just want to get another seeing i travel alot and want a good running engine and tranny for it.
Old 09-05-2006, 12:01 AM
fordredneck1989 fordredneck1989 is offline
Re: Need New Engine
my motor burns like 2 qaurts a week i'm building a engine for mine
Old 09-05-2006, 04:06 PM
Re: Need New Engine
do you have a leak or something in yours, i want a new engine for mines. a quart every 500 miles isnt bad but 500 miles go by quick for an average driver.
Old 09-05-2006, 05:32 PM
KimMG KimMG is offline
AF - Advisor
Re: Need New Engine
Using a quart of oil can just be valve stem seals. Have you done a compression test? A leak down test? Are you able to do repair work yourself? What motor does your car currently have?
Old 09-06-2006, 12:09 AM
Re: Need New Engine
i think its the maf causing it b/c i ran it a week w/o the maf, and i didnt smoke when i started it but when i put the maf back on it started smoken, it seemed like it had alot more power w/o the maf i dont know why and gas milage is way better
92 mgm
4.6l that burns 2 quarts in a week
building up another 4.6l to drop in it (blown)
