Old 08-30-2006, 07:06 AM
kevincooke2176 kevincooke2176 is offline
replace dashboard lights
I have two lights out in the instument cluster in my 93 Tauras wagon. How does the cover come off to access these lights. Thanks for the help
Old 08-30-2006, 12:04 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: replace dashboard lights
Hopefully someone who's done this recently will chime in. My recall is there are a couple of screws above the bezel that you need to remove to get the trim piece off. Then you remove the screws around the instrument cluster and slowly wiggle it out. There will be a couple of connectors plugged in to the back side of the cluster that you will need to release and I believe a speedometer cable that you will need to disconnect too. I don't think you need to reach around from underneath the dash to release the speedo cable, but you may need to. Once you have the cluster in your lap, there are bulb holders twisted into the cluster on the back side. A quarter twist removes them and the bulbs pull out of the holders.
-Rod
Old 08-30-2006, 03:49 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Also be sure to disconnect the shift indicator cable. If ot the little string will break and you will need a new one. Other than that, Rod has it pretty well nailed.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-30-2006, 04:36 PM
shorod's Avatar
SHO No Mo
Oh yeah, I suppose the wagon would have the column shift. I'm used to floor shift models. The only Taurii I've owned have been SHO's.
-Rod
