Old 08-30-2006, 01:28 AM
chopstick1981 chopstick1981 is offline
replace window motor?
I've got a drivers side window that is totally dead. Before i rip the door panel off do you guys have any advice for me?
Old 08-30-2006, 12:35 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: replace window motor?
check the fuses, just to make sure you didn't blow one.
otherwise, broken window regulators are common problems on cars that are 10+ years old. i've had to replace both of mine since i got my car 4 years ago.
our window regulators contain some plastic peices which are prone to breaking. this is the weak point. here http://www.clan-davidson.com/jd/vr4/garage/windowreg/ a site where some guy has provided a way to beef-up the plastic parts to protect them from braking again. when replacing your regulator (if you must replace it and it's beyond repair), i suggest you do these upgrades to prevent a future incident.
good luck and welcome to AF!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-30-2006, 02:17 PM
CHRIST75 CHRIST75 is offline
Yep that's very good info, Also check Stealth 316 on the garage section lots of info there.
Old 08-30-2006, 04:30 PM
3kvr4's Avatar
3kvr4 3kvr4 is offline
Send a message via AIM to 3kvr4
The ones under the steering wheel?
Old 08-30-2006, 05:23 PM
Linebckr49's Avatar
umm...ya. there are only 2 groups of fuses. under the steering wheel, and under the hood next to the passenger headlight. so i would suggest check both groups.
93 3000GT base
