Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-29-2006, 09:44 PM
duster1979 duster1979 is offline
1994 door panel removal
The driver's side window on my 1994 Grand Marquis has stopped working. I've dealt with enough of these on other cars that I'm pretty sure I can get it going without too much trouble, but I can't figure out how to get the door panel off! Any advice would be greatly appreciated!
Old 08-29-2006, 09:59 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
Re: 1994 door panel removal
Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front
  1. Detach all connectors from the switch housing.
  2. Remove the door inside handle cup.
  3. Remove the push pin from the door trim panel upper front extension and remove the screw.
  4. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel.
See Figures 6, 7 and 8
Fig. 6: Detach the switch housing electrical connector and remove the housing
Fig. 7: Remove the door inside handle cup
Fig. 8: Remove the screws from the door panel in the front and on the upper extension
  1. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  2. Lift the door panel upward and snap out the panel.
See Figures 9 and 10
Fig. 9: There are also retaining screws located in the map pocket as well as ...
Fig. 10: ... along the bottom edge of the door panel
  1. Disconnect the necessary wire harnesses and remove the panel.
Old 08-29-2006, 10:52 PM
reekor reekor is offline
Along with what is listed above the 92-94 Grand Marquis has a handle strap with two screws in it, you have to peel the edges of the handle strap to get at them. Also when removing the door panel you have to push it up before removing it or you will break the plastic clips that hold the door panel to the door.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
