Old 08-29-2006, 09:42 PM
broken gtp broken gtp is offline
plz help me out here!!!!
i have just opened my hood and noticed that my s/c belt had burnd off. Also i noticed that the pulley right below my s/c had melted too.. is ther a way to find out the name or size of it so i can go to a car store and replace it.... also i need to change the belt on it... i heard that the size is a 93 1/2''.... my modle is the 2000 gtp 3800.... plz help me out.. also is this a job that i can do or is it something that should be take to a shop...
Old 08-29-2006, 09:59 PM
GaryFenza GaryFenza is offline
Re: plz help me out here!!!!
i would say......to be on the safe side, take it to a shop. Good luck!
Old 08-30-2006, 07:40 AM
slimfatboy slimfatboy is offline
Sounds like an idler pulley seized up. You may be better off going to the parts store and figuring out if its the ribbed one or not. The SC belt is not 93.5 inches, I think the number for a stock sc belt is 4060660 by gatorback. Both parts totalled around 60 dollars, if my memory serves me correctly. Easily doable with a 15mm socket, ratchet and 20 minutes.
As always, correct me if i'm wrong.
Old 08-30-2006, 09:48 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree he'd be better off saving some money and DIY the job.
The serpentine drive belt length is 93.5". The SC belt with a stock SC pulley is 66.0".
Timeslip 08/12/06
AF Community Guidelines
Old 08-30-2006, 12:01 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The pulley below the S/C could be the S/C belt tensioner pulley, or the S/C belt idler pulley, depending on if it's toward the center of the engine, or toward the front of the car.
Goodyear S/C belt idler/tensioner pulley numbers are as follows:
smooth -49007
grooved-49003
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-30-2006, 12:30 PM
BNaylor's Avatar
The part that normally goes bad on the SC drive system is the tensioner pulley. There are times it goes to pieces. The pulley size is 3" stock.
For a 2000 GTP the GM Part number is 12564506, GM List $83.74. Expensive.
As Rich pointed out you can get a GoodYear aftermarket and there are other companies.
The best place to get tensioner pulleys for a GTP is ZZPerformance.
http://www.zzperformance.com/grand_p...ts1.php?id=195
Timeslip 08/12/06
