Need pic of '95 OBD1 port
The guy I bought my car from said that the PCM and block was from a 95 but the port looks like it's from an earlier model OBD1 and the cable I just bought for the '95 from moates.net does not fit. The previous owner told me that he made his own cable and I'm wondering if he hooked up an older style diagnostic port to make it easier on himself. I just really need to see what a '95 LT1 port looks like so that I can try to figure out what's what.
I just got the cable tonight and I haven't had a chance to look at the PCM but if it's a '95 should it have the 8051 code on it somewhere?
![]() '91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect... |
Re: Need pic of '95 OBD1 port
the 95 port looks like an obd2 port but if you look inside of it it actually only has a few prongs
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
http://www.mastach.com/index.php?mod...onnectors&l=en
it's the 16 pin
Well, it looks like I have the right cable for a 95 but the wrong PCM or connector. What would be the best way to tell what year the PCM is from?
You probably have a 94 OBD1 Hybrid system but the diagram below will tell you if thats the case but the PCM itself for a 94 and a 95 is exactly the same. The engine itself has a couple differences between a 94 and a 95 though.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Great info guys, thanks a lot. It is a 12 pin connector and going by the picture above only the B, A, and M terminals have pins in them so it seems like maybe it was a custom job. Any idea how I could figure out what's going on?
EDIT: The only reason I'm a little confused is because my car in an auto with a 4l60e, so shouldn't it have the TCC terminal populated?
I have the OBD2 terminal. This is the cable that I have http://www.moates.net/aldu1cabl2-combo-p-128.html.
What you need to do is take two paper clips or jumper wires and have terminal 5 on the cable end go to terminal A on the datalink terminal and have the the other wire or clip go from terminal 9 on the cable end to terminal M on the datalink end. Then it should read and flash correctly.
You want to test the connection with a scan first though using free scanning software beforing you start the flashing and reading programs.
Great, that makes sense. I'll try it out tomorrow and let you know how it goes. Thanks again for all the help.
No problem and let me know if you need some scanning software. I can send you a link to some free stuff to use.
Alright it looks like the cable and paper clips are working, but I'm having a hard time finding a good scan tool. Any suggestions?
I will try to find my disc of freescan DL, If I can find it where do you want me to email it to.
That would be awesome if you could send it to [email protected]. What flashing software would you recommend, I've heard really good things about Tunercat.
I couldn't get the link threw the guys site to work for the DL but I found a old default link threw a site that leads to the page to DL freescan. So here it is http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
