93 grand 5.2 starter problems
hey everyone
I have a 93 5.2 that I have had for 7 years now and this morning when I tried to start nothing exept solenoid so I bought and replaced it and in the process the neg battery cable came loose and re-connected the battery and a few sparks so I went ahead and finished and same thing so I went and had it checked they said it was fine so I replaced the stater relay and ignition fuse that I blew and still nothing except solenoid works it wont engage the bendix any ideas thanks rob |
Re: 93 grand 5.2 starter problems
ok just had a friend turn the key and the bendix does engage but now spin at all thought I would and that
Try sticking a socket and ratchet on the crank pulley bolt and turn the engine clockwise. Does the engine spin? If so it is either a week starter, prolly doesn't have enough power to spin the engine at that point (point where it is at it's highest compression, prolly 3 or more cylinders on a compression stroke). |
thanks dksob it turned out to be a bad wire from battery in the middle ,had some heat damage well its all fixed now.
