Altima fans
does anybody know how to wire up altima fans? how and what do i bolt it down to?
Re: Altima fans
shit im not on my comp cause its broken but i did hve a link for it. been covered many times on zilvia though
Re: Altima fans
can someone please provide a link? i found a few instructions but for aftermarket fans, is it the same concept?
thank you sideways |
Re: Altima fans
Electric fans are electric fans, no matter where they come from: another car or from a speed shop's shelf.
I had my e-fan wired to an adjustable thermostat from Heavy Throttle but this little device failed me. Seemed like the potentiometer kept vibrating itself to max. temp. and would overheat my engine at a stop. So here's what I did: I bought a 6-dollar relay from Advance Auto and placed it inline between the battery and the fan. The other wire is connected directly to ground. Relays are genius little devices and are pretty simple to figure out. The switching voltage is pulled from the EGI relay, whatever EGI means. Polarity is pretty simple to figure out; put each wire on a battery terminal and if it spins the wrong way reverse what you're doing and mark them with tape + and -. Make sure to solder everything and use heatshrink so you don't look like an ass when you open the hood! With two fans you have two options: wire them in series to pull less current from your battery (and from other electronics) or wire them in parallel and have them move much more air.
'91 240sx Coupe SE (Black) - SR Redtop, Auto-Manual Conversion, many go-fast goodies, and over 10 grand in new parts ![]() '91 240sx Hatchback SE (Burgundy) - Sold ![]() '03 350z Touring 6MT (Silverstone) - Replaces 240sx Hatchback, Clarion Double-DIN DVD player
Re: Altima fans
i was thinking about just having mine hooked up to a switch that would in my car. i have the thermostat gadget too and i dont think it works verry well.
93 hatch W/SR20 BLKTOP, FMIC, blitz BOV, tien coilovers, rsr exmag exhaust, downpipe, wallboro fuel pump, custom oil cooler W/ ebay oil filter relocation kit. apexi afc neo next upgrade = z32 brakes all around 210 hp/215 tq to the wheels |
Re: Altima fans
I don't get relays.
Re: Altima fans
Re: Altima fans
So why Altima fans, do they bolt up to the radiator, is the radiator on an altima the same size or even the same radiator?
"If God were suddenly condemned to live the life which he has inflicted on men, he would kill himself" -Alexander Dumas (1802- 1870)
Re: Altima fans
Same engine, I would thin kthe radiators r similar sizes.
Re: Altima fans
the best way is to have your fan wired to a thermostat in one of your coolant hoses so that the fan turns on when it needs to be on and is off when it doesn't need to be on. pm me if you want the kit. its pretty cheap and easy to install.
add: and to fit the altima fan into a 240, you need to saw off at least 2 of the corners. if you want it to fit properly and snug, cut all 4 corners. thats the best way to have it fit between the frame rails.
http://www.cardomain.com/id/dbo240 ![]() ***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE*** |
