Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 08-29-2006, 04:03 PM
xunforgivenx86 xunforgivenx86 is offline
2003 headlight and taillight strobes
I am a vol fire fighter and i am looking to put storbe lights in the head and tail lights in the turn signals and break lights in the back and then in the turn and head light in the front. is this possable and if so whats the easiest way to do it?
Old 08-29-2006, 05:20 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: 2003 headlight and taillight strobes
First off all you have to buy special little bulbs that you can find in any auto parts store. The are usualy long and slender. I believe you have to remove the bulbs and then the lamps. Now because the lamps are sealed from water you will more than likely have to drill the back side of your lamp. The hole should be just the right size so that the strobes fit snug tight.
Good Luck.
Old 08-29-2006, 06:29 PM
yeah i tried those they deff are not bright enough for what i need, im getten a set from wheelen which requies a 1inch hole to be drilled and the light fits in there.
