Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-29-2006, 04:03 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Temporary Headgasket fix...
Well, many of you know that my head gasket sprung a leak. I am currently getting a head and getting parts to port and fully build the head. However, I want to try and replace my current headgasket with like a 40 dollar head gasket from advanced auto. This will only be on for like 3 months but, I can't deal with not being able to race my car anymore so I want a fix for those 3 months. Any tips or suggestions? Don't worry I'm not getting a super cheapo but, I'm not getting a copper gasket or anything. A buddy of mine(also has a dsm) has had good results with I think he said Feltech head gaskets so I am going to pick one up. This will also let me figure out if the head is cracked or warped depending on if it still overheats and what not. This will also give me practice with the head and all for when my head is complete the build and I have to swap it.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 08-29-2006, 04:44 PM
NateS's Avatar
Re: Temporary Headgasket fix...
I just got home from advanced auto parts. I got a Fel-Pro head gasket. I said feltech but, it is a fel-pro. The buddy who recommended it has rebuilt 2 motors already and he said it is a good head gasket but, I shouldn't boost the crap out of it.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-29-2006, 05:41 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
It will handle around 20psi. Felpro makes good gaskets.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-29-2006, 07:32 PM
NateS's Avatar
So 20psi with ARP head studs or with stock head studs? Think I will be okay running 19psi of boost on it at the track?
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-29-2006, 09:16 PM
Killa's Avatar
Killa Killa is offline
True most of my gasket in my talon, is felpro.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-29-2006, 10:04 PM
blk_srt's Avatar
20psi on arps. You should never resure the stock ones, they are torque to yeild bolts and will never have the right torque again
Mods:
kjewer1 kjewer1 is offline
AF - Advisor
I would always run ARPs, there are no benefits to sticking with the stock bolts that stretch when torqued, stretch when running high cylinder pressure, and are not reusable (even if they are "in spec" for length, IMO).
I'm not sure how good the felpro gasket is, but the stock composite gasket always worked very well for me, and I ran them right up until the end on the 2g. I'd still be running them, but the EVO uses a metal MLS HG stock. I'm sure the felpro will hold long enough for you though, but remember that timing is far more critical than boost as far as the HG goes.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-29-2006, 10:08 PM
blk_srt's Avatar
By the way what happened to the gsx?
Mods:
Old 08-30-2006, 07:16 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
The fel-pro is a good gasket (as everyone else has said)... it's in my '91 TSI daliy... and i'm boostin' 17...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 08-30-2006, 09:20 PM
NateS's Avatar
Okay, sounds good. Yes I do have arps and I was not planning on replacing them, I am told they are good to reuse cause they are just so damn awesome lol. Remember though, that this head gasket only had to last me like 3 months while my other head is getting built then the titan headgasket is going on. I was running 24psi race and 19psi normally but, I guess I can hold back to just 19psi for the 3 months lol.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-31-2006, 09:13 PM
NateS's Avatar
Okay, round 1 is done. I got the head off and the gasket off. The head is sitting about 8 inches above my block and the intake manifold is still on it. I plan on just lifting the head to clean it and replace the gasket. BUT, two things worry me.
First off, when removing the nuts for the head studs, two of the studs came out instead of the nut. I am kinda nervous about this because I know oil and or coolant got down into the hole. I know I will have to clean this out but, I am not sure how and I am not sure how I am going to get the nuts off the studs then put the studs back into the block.
Second, I slid my timing belt off of the cam gears and it came off fairly easy. However once I got it off I tried to slide it back on to see how hard it would be and damn is it hard. I know you can loosen the tension on the belt and slide it back on then tighten it but, I do not have a tool to do it. A few of my friends said that I should be able to slide it back on with a little effort though.
Third, I thought I had everything zeroed out but, I deffinatly didn't. When I slid my timing belt off both cam gears spun a little bit. I am 99.9% possitive they both spun the same amount but, I am going to check this tommarow.
Well tommarow is round 2. Wish me luck and if you have spotted anything that I have done horribly wrong or that will possibly fuck my car up real bad please be kind and let me know. Haha thanks.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 08-31-2006, 11:14 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The timing belt shouldn't be able to "slide off" or "slide on" easily, otherwise it could come off while running. When you took it off, the tensioner automatically tried to tension up the belt and now it's tensioned to the max, that's why you can't slide it back on. If you don't know how to do a T-Belt job, let me know and I can get you directions off of Mitchell On Demand, otherwise its in the VFAQ. I'm not sure what to do about your studs, but maybe try putting them back in with some lock tite and then try removing the nut after letting it dry for awhile, that's what we did on my buddies sprint car rear-end studs.
Oh yeah, and slap your friends because they are idiots for telling you the t-belt should slide back on easily.
95 Talon TSI AWD
97 Eclipse GST
Old 09-01-2006, 08:33 AM
AF - Advisor
You can still get the belt back on without special tools. Remove the hydraulic autotensioner and compress it very slowly in a vice, and stick the grenade pin in. If you don't have 30 grenade pins lying around like I do, a small drill bit works. Line everything up, install the belt, install the tensioner, double check the marks, and pull the grenade pin/drill bit. Tension is now exactly what it was before. Wether it's right or wrong, it's the same
The cam gears jumped because of the spring pressure pushing against the cams. Perfectly normal. When putting the belt back on, get some friends to put wrenches on the cam gears and hold them line up for you while you put the belt on and zip tie it to the gears. Then run the belt around the oil pump sprocket (phase the rear bshaft if you still have them, with the mark at 12 oclock let go of the pulley. If it rotates toward the mark it's good. If it rotates away from the mark, turn it one full turn and do the test again, and it will rotate toward the mark this time. Pure fuckin magic). Then run it around the crank making sure it is at the timing marks, then around the tensioner pulley (make sure you do not loosen that 14mm bolt in the center of the tensioner pulley, or you will be doing a full retension).
The nut should come right off the stud once it's out. Read the page on my site about ARP head studs if you haven't already.
Kevin Jewer
Old 09-01-2006, 03:02 PM
NateS's Avatar
Thanks everyone, I am about to head out to the garage so I will be sure to let you know how it goes.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 09-01-2006, 09:06 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I used a tiny allen key for the tensioner, it might slide out easier than a drill bit. I also used three allen keys to tension the tensioner pulley, I put one in each hole on the tensioner and used a third (larger one) to spin the pulley byputting it between the two others and prying.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
