part location? Please help!!!!!!!!!!!!!!!!!!!!!!
Can anyone tell me what, and where the computer under my dash is, whatand where an ECM is, and where the camshaft position sensor is? pictures would be helpful. I have a 1995 lesabre custom, and i'm trying to fix it myself
Re: part location? Please help!!!!!!!!!!!!!!!!!!!!!!
The ECM module should be on the passenger side of the car under the dash behind the glovebox area. The camshaft position sensor should be located at the front of the engine by the crank and harmonic balancer around the 10 o'clock position on the block.
If this LeSabre is a 1995, it may have the OBD11 PCM. If so, it should be under the hood. Check the sticker on the fan schroud to see if it is OBD11 compliant.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
if i buy a new computer, would it have to be programed? or would it already be set.
http://bellsouthpwp.net/p/a/padgett46/cammag.htm
Cam sensor and magnet locations on a series 1. Should be very similar on a series 2.
-Eric 89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc. Basic H/C body info:http://www.3800power.bravehost.com/index.htm http://www.cardomain.com/ride/2318168 |
How about a shot of a camshaft position sensor on a SII 3800. The plastic cover and harmonic balancer are removed. Plus it it shows the crank position sensor to the right.
i see anywhere it said, but it does have a chip in it and dosnt have to be flash programed.
which one is the crank position sensor?
i see it, upon replacing it, do i need any special tools? does it have to be "set"? same question for the cam sensor. does the balancer have come off?
Another issue is that even when you think it is properly adjusted, tightening down the screw which locks the sensor in place can move the sensor, thus making your work in setting it moot and you have to start over. It can be tricky work. The cam sensor is much easier. You simply get the old one out (rock it left and right while pulling backward and it will eventually come out), and put the new one in. You need to check the condition of your cam sensor magnet while it is out. If it needs replacing, DO IT. To do it without pulling the front cover off, do this: http://bellsouthpwp.net/p/a/padgett46/cammag.htm You can probably replace the cam sensor without removing the harmonic balancer, but it would be harder (and maybe not possible--I can't remember if it overlaps the sensor). You cannot replace the crank sensor without removing the harmonic balancer. |
Good post, however, some clarification is in order. No special tool is required to install a crank position sensor on a SII 3800. There is no air gap setting needed. The CKPS is preformed and a fixed fit once properly bolted and torqued down on to the two studs. On the harmonic balancer puller special bolts are needed to remove the harmonic balancer. The typical rented ones will not come with them. The bolts (total 3) are 1/4" X 3" 28 NF (National Fine). You may be able to replace the camshaft position sensor, however, it will be alot easier to remove the harmonic balancer and the plastic protective shield. The plastic shield is blocking the access to the sensor. It recommended to replace both sensors while it is all apart. If the original poster needs a tech procedure with pics I will be happy to provide it. Just PM me. BTW - The backside of the balancer should be inspected after removal. The teeth on the rings is what breaks the signal for the CrankShaftPosition Sensor to read properly. Inspect them for possible damage. The above is only applicable if he has a SII 3800 Vin "K". He may have a 3.8L Vin "L" depending on when it was made during the production year. However, the Vin "L" and Vin "K" sensors are identical and have the same part number.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 09-07-2006 at 10:08 PM. |
