Old 08-29-2006, 01:29 PM
Whomp Whomp is offline
Unhappy 97 Escort Engine Misfiring
Hi.
I have a 1997 Escort LX "Sport" and the other night the engine started sputtering and dying. Gas gauge is broken so we thought it was running out, but filled it and still no good. Service Engine Soon light had been on so I had the codes pulled, and it said that there was a primary/secondary circuit failure on the ignition coil, as well as misfires in cyls 1, 3 and 4.
2's doing ok, I guess.
Anyway, new plugs and wires, no help.
New coil, no help.
Don't have a mechanic I trust, someday I hope to find one. In the meantime, I'm looking for easy things I can look at with basic tools.
Thanks all, this is a great resource. Wish I could contribute, but what I don't know about cars would fill a bunch of books
Old 08-29-2006, 03:45 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 97 Escort Engine Misfiring
Look for a vacuum leak and check the timing.
Old 08-30-2006, 09:47 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
The coil pack may be going bad causing those cylinders to miss. Hook a spark tester to each cylinder one at a time and check for spark.
Old 08-30-2006, 11:43 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Check the wires too after you check the coilpack like the other post suggested - at least do the nighttime check where you open the hood at dark time and see if you notice arcing of the spark.
Also after codes where pulled did they reset the computer ?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 09-01-2006, 05:41 AM
Davescort97 Davescort97 is offline
Escort guy
Make sure the ignition wire boots are pushed all the way onto the spark plugs. Check the primary electrical wires going into the coil pack harness and make sure the secondary leads off the pack are pushed all the way into the coil pack. I've seen 8 mm wires fry inside of 30 minutes on escort engines. The stock wires you buy at the parts place are not that good. Try to find some good 8.5mm to 10mm wires. When was the last time the positive battery terminal cleaned? Neutralize the corrosion with some baking soda and water with an old tooth brush. Rinse well. Get a good tight connection. A marginal connection at the battery will cause problems in other places in the electrical system. Leave the battery terminal unhooked for at least 15 minutes and it will reset your computer and check engine light.
