Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 08-29-2006, 01:25 PM
capnrobgus capnrobgus is offline
Mark Gets hot
I need help... My 1993 Mark VIII gets hot ( gage maxes out) I have replaced, water punp and the thermasstat. I have tried to flush the radiator many times and even added radiator cleaner..... nothing works... I have just orders a radiator off e-bay.... Is there anything I am overlooking befor I install the new radiator....
Please help
thanks
capnrob
Old 08-29-2006, 10:03 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Mark Gets hot
Are you sure the gauge is accurate? Usually if it maxes out the car will boil over or push an excessive amount of coolant into the overflow tank.
If this is not happening, you may not actually have a problem, except for a defective gauge or sender. Try installing an aftermarket gauge and see what it reads.
Old 01-09-2009, 04:11 PM
96markviii 96markviii is offline
Re: Mark Gets hot
I am having the same problem with my 96. I have changed the thermostat, water pump, heater core I flushed my radiator, replaced almost all of the hoses and still it gets hot. If you find a solution to your problem would you please e-mail me @ [email protected]. I have been fighting this for a while now and I am getting tired of fixing dents I keep putting in my car.
Old 01-10-2009, 08:12 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Mark Gets hot
Be sure to get the air out of the cooling system or you will have "hot spots".
There is a coolant refill procedure at the bottom of ... This page.
Old 06-16-2009, 12:02 PM
mikemark8 mikemark8 is offline
Re: Mark Gets hot
+1-these things are real PITA to 'burp' but it has to have ALL air removed from the system or it will not cool properly-since you have been in the system numerous times, you have undoubtly had to refill it-did you remove the crossover cap and fill the system there after filling at the overflow cap?
