Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-29-2006, 01:16 PM
jasholt jasholt is offline
98-02 Rodeo-Ever had the Timing Belt break?
At how many miles?
Old 08-29-2006, 02:05 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 98-02 Rodeo-Ever had the Timing Belt break?
I've only read about a couple (2 that I can think of). Most change them by 120k. I've read a couple of post of upto 180k on the orginal belt.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-29-2006, 03:46 PM
surferfletch surferfletch is offline
What year was the one I just read about on here that the guy bought the Rodeo for $400 and slapped a new belt on and everything was OK? That's the only one I've heard.
Old 08-29-2006, 11:06 PM
fromh311 fromh311 is offline
1995 but it had a new belt installed at 70K before I got it
Old 08-30-2006, 08:40 PM
ronhl80 ronhl80 is offline
I just replaced mine at 145k, I don't know if it was done once before but it was in fair condition, only some minor cracking on the smooth side.
Old 08-31-2006, 12:02 AM
bishop242 bishop242 is offline
I'm at 120,000 on my 00 Rodeo with all orig. parts including water pump.
Starting to get a little clatter sound under load. I'm pretty sure it's the tensioner getting tired.
I'm a huge believer in preemptive maintenance, but in this case I'm probably going to let it go until the water pump gives out or the belt jumps a tooth due to the tensioner.
2000 Trooper limited
1991 Trooper V6 "The Tank"
2000 Rodeo LS 4x4 SOLD
1989 Trooper 2.6 - R.I.P. Killed by a 6$ heater hose
"Tow strap? Sure... I'd be happy to pull you out"
Denver Colorado
Old 08-31-2006, 02:17 AM
Tom01Rodeo Tom01Rodeo is offline
I figure by next summer I'll be approaching 100K and will look into replacing it then along with cooling hoses. I really hope to keep it around till 150K without major issues.
Old 08-31-2006, 03:11 AM
Ramblin Fever Ramblin Fever is offline
Just did my 2nd set at 152k miles - waterpump croaked at 92k miles, causing tensioner to weaken, belt jumped a tooth; no damage.
Did 1st set (waterpump, belt, tensioner) as preventative maintenance at 59k miles - if I had known the 3.2L sohc was a NON-interference engine, I would've left it alone tell either the tensioner or pump gave out.
Should be good to go for another 90-100k miles.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-31-2006, 03:46 PM
jimwelsh's Avatar
jimwelsh jimwelsh is offline
Question Re: 98-02 Rodeo-Ever had the Timing Belt break?
I'm sure this has been answered before, but for my own piece of mind, is the 3.2 v6 in the 1999 Rodeo a interference or non-interference engine?
Thanks,
Jim
Old 08-31-2006, 03:52 PM
Isuzu Guy
non-interference
-Ryan
Isuzu Moderator
Car Show Tips
Old 08-31-2006, 04:02 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Originally Posted by amigo-2k
non-interference
like he said...
but if you're interested, or for others stopping here. . .
canuklehead posted a good link to the Gates Timing Belt Replacement Guide at this thread
http://www.automotiveforums.com/vbul...d.php?t=612770
1997 Turns but doesn't start
the catalog not only tells you what gates belt number you need, but whether the engine is interference or noninterference.
fwiw the page numbers are
isuzu catalog pp 11 - 12; pdf pp13 -14
passport catalog p 10; pdf p 12
hth
/bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 09-21-2006, 08:52 AM
srpope80 srpope80 is offline
150K here, belt was perfect when removed! (Water pump was starting to weep)
Old 09-21-2006, 11:46 PM
wildlysmiley wildlysmiley is offline
Yes, mine broke at about 89000 miles and to repair the heads and gaskets and put her all back together with a new belt was quite pricy! over a grand...so, my advice is to be safe rather than sorry.
bon chance!
Old 09-21-2006, 11:55 PM
What engine did you have wildly? I can't remember if it was the non-interference 3.2L or not...
Old 09-22-2006, 12:04 AM
http://www.automotiveforums.com/vbul...d.php?t=545766
It was a '99 3.2L. Head damage following a timing belt tensioner mishap on a non-interference engine.
